Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement
Wat je nodig hebt
    1. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Lower Case: stap 1, afbeelding 1 van 1
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 2, afbeelding 1 van 1
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Battery Connector: stap 3, afbeelding 2 van 2
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 4, afbeelding 1 van 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Optical Drive: stap 5, afbeelding 1 van 1
      • Disconnect the camera cable connector from its socket on the logic board.
      • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 6, afbeelding 1 van 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 7, afbeelding 1 van 1
      • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 8, afbeelding 2 van 2
      • Remove following two screws:
      • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
      • One 8.6 mm Phillips screw
      • One 3.9 mm Phillips screw
      • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 9, afbeelding 1 van 1
      • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 10, afbeelding 1 van 1
      • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: stap 11, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: stap 11, afbeelding 2 van 2
      • Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
      • Peel the hard drive cable up from the channel within the subwoofer and right speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 12, afbeelding 1 van 1
      • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 13, afbeelding 1 van 1
      • Remove the following six screws securing the subwoofer and right speaker to the upper case:
      • Two 3.2 mm Phillips screws.
      • Two 12.3 mm Phillips screws.
      • One 2.5 mm Phillips screw.
      • One 8.3 mm Phillips screw.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 14, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 Subwoofer & Right Speaker Replacement: stap 14, afbeelding 2 van 2
      • Use the flat end of a spudger to dislodge the right speaker from its recess in the upper case.
      • Lift the subwoofer and right speaker assembly out of the upper case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
515.764 Reputatie
406 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
86.241 handleidingen geschreven
3Gids Commentaar
Hi, since a few day my right speaker crackles (in the bass), do you think it should be changed ? what could be the cause of the damage ? If so, is this type of piece ok ? (macbook pro Unibody 15" Mid-2102) THX
https://repairmacparts.com/product/haut-...
macgyver07 - Antwoord Deel
That looks like the correct part. Crackling in the speaker is usually caused by being blown out (volume too high and it damages the speaker membrane) or other times some dirt or dust or debris gets caught in the speaker and vibrates off the membrane. Sorry no one replied until now (3 years later!)
stevebsiegel - Antwoord Deel
Great instructions all the way through. Now I have sound out of the left speaker. Sounds much better than the scratchy breaking up sound. Had trouble reconnecting the woofer. It won't reconnect like the others that snap in. The last I don't have a start up sound
Richard Urrutia - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 130
Altijd: 20,687
