Inleiding
The right speaker and subwoofer are a single unit. Use this guide to replace it if either has stopped working.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Disconnect the camera cable connector from its socket on the logic board.
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
Peel the hard drive cable up from the channel within the subwoofer and right speaker.
13 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi, since a few day my right speaker crackles (in the bass), do you think it should be changed ? what could be the cause of the damage ? If so, is this type of piece ok ? (macbook pro Unibody 15" Mid-2102) THX
