Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement
Wat je nodig hebt
    1. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, Lower Case: stap 1, afbeelding 1 van 1
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 2, afbeelding 1 van 1
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, Battery Connector: stap 3, afbeelding 2 van 2
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 4, afbeelding 1 van 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, Left Fan: stap 5, afbeelding 1 van 1
      • Remove the following three screws securing the left fan to the logic board:
      • Two 3.5 mm T6 Torx screws.
      • One 4.2 mm T6 Torx screw.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 6, afbeelding 1 van 3 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 6, afbeelding 2 van 3 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 6, afbeelding 3 van 3
      • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
      • The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 7, afbeelding 1 van 1
      • Lift the left fan out of the upper case.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, Logic Board: stap 8, afbeelding 1 van 1
      • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 9, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 9, afbeelding 2 van 2
      • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
      • Lift the right fan out of its opening in the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 10, afbeelding 1 van 1
      • Pull the camera cable out of its socket on the logic board.
      • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 11, afbeelding 1 van 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 12, afbeelding 1 van 1
      • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 13, afbeelding 1 van 1
      • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
      Vraag FixBot
      Voeg opmerking toe
    7. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 14, afbeelding 1 van 1
      • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      Vraag FixBot
      Voeg opmerking toe
    8. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 15, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 15, afbeelding 2 van 2
      • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
      • Lift the cover off the logic board and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    9. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 16, afbeelding 1 van 1
      • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    10. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 17, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 17, afbeelding 2 van 2
      • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    11. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 18, afbeelding 1 van 1
      • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
      Vraag FixBot
      Voeg opmerking toe
    12. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 19, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 19, afbeelding 2 van 2
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      Vraag FixBot
      Voeg opmerking toe
    13. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 20, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 20, afbeelding 2 van 2
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Be sure you are flipping up the hinged retaining flap, not the socket itself.
      • Pull the keyboard backlight ribbon cable out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    14. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 21, afbeelding 1 van 1
      • Remove the following nine screws:
      • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
      • Two 8 mm T6 Torx screws on the DC-In board
      Vraag FixBot
      Voeg opmerking toe
    15. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 22, afbeelding 1 van 3 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 22, afbeelding 2 van 3 MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement: stap 22, afbeelding 3 van 3
      • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
      • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
      • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement, MagSafe DC-In Board: stap 23, afbeelding 1 van 1
      • Disconnect the DC-In board by pulling its cable toward the heat sink.
      • Pull the cable parallel to the face of the logic board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
42 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
515.764 Reputatie
406 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
86.241 handleidingen geschreven
6Gids Commentaar
Dont want to double post so please refer to the guide for the display to see my issue, but folwed teh guide to the T. The only anomaly i found ater reseting everything again is darkish tint ont he display cable, the rest of hte story is on my post on guides for displa. any help guys will be greatly appreciated. I'll defintelyl guys you guys business from here on how, And yes i know i work or apple but his machine ha my bitcoins.and pgp keys. and i still love her.
mark Andrews - Antwoord Deel
Good tutorial. New DC board installed and Macbook now charges without getting hot at all.
bill borez - Antwoord Deel
Thank you, followed this and fixed my macbook. My only difficulty was with removing the display cable until I realized that there’s a hinged wire clip in front of the socket that must be lifted up and over the socket before removal. Very helpful guide..
robertlucier - Antwoord Deel
Thanks for this tutorial ,New DC Board installed but my macbook a1286 charged 60% and he doesn’t work.
how can i see to check what going wrong i know this channel ,https://www.youtube.com/channel/UCl2mFZo...,
But i dont know if should check data sense line or which step and material i need (multimeter)
thanks for any reply
sorry for my english im “French” :)
soufiane - Antwoord Deel
Excellent tutorial. Whole project start to finish was successful in under an hour. Extreme attention to screw size/lengths was great and the order was also perfect.
Ben Patch - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 106
Altijd: 25,923
