Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  2. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
  3. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  4. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 4, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  5. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  6. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: stap 6, afbeelding 1 van 1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 956
