Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Disconnect the camera cable by pulling the male end straight away from its socket.
Peel the camera cable off the adhesive securing it to the optical drive.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
Lift the Bluetooth board/cable retainer assembly out of the upper case.
Use a spudger to pry the optical drive connector straight up off the logic board.
Remove the single 3.5 mm Phillips screw securing the inner side of the optical drive to the upper case.
Remove the two 3.5 mm Phillips screws securing the outer side of the optical drive to the upper case.
Lift the optical drive from its left edge and pull it out of the upper case.
