Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement
Wat je nodig hebt
  1. MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Seven 3 mm Phillips screws.
    May be helpful to have more distinct colors to identify the different screws.
    Victor Caamano - Antwoord
  2. MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement: stap 2, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement: stap 2, afbeelding 2 van 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement, Left Fan: stap 3, afbeelding 1 van 3 MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement, Left Fan: stap 3, afbeelding 2 van 3 MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement, Left Fan: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  4. MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement: stap 4, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2009 Left Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove three T6 Torx screws securing the left fan to the logic board.
    • Lift the left fan out of the upper case.
Conclusie
70 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Connecting the fan to the logic board is unclear. Could you walk through that a little more clearly?
kamoako1 - Antwoord
When connecting the new fan to the logic board, set the connector piece above its socket on the logic board and then gently press down. It should click together.
k. -
quite easy. i’m very happy with this manual. Though connecting the new fan until it clicks is the most difficult part. thank you!
Oliver - Antwoord
Great guide, easy work to do! If I can do this, anyone can. If I can do this, someone who does not exist almost can. Not quite! But almost. I was happy to get that squalling and howling old fan out of my MacBook Pro, and thereby to end the squalling I got from my family over the noise it made. Like the old one, the new fan works great, but it is new, and quiet, and I am thankful. Happy customer.
pstewart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 42,076
