Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a non-functioning Bluetooth board in the Anti-Glare option of the Mid 2009 MacBook Pro.
The Glossy display option does not have this display-mounted bluetooth card, it is found under the clutch cover.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Remove the single Phillips screw securing the Bluetooth board to the retainer.
Lift the Bluetooth board off the retainer.
3 andere personen hebben deze handleiding voltooid.
4 opmerkingen
I second roblamper's question... Yosemite/iOS 8's new "Handoff" as well as "OS X+iOS AirDrop" feature(s) appear to be thwarted on the Mid 2009 MBP due to the existing Bluetooth hardware limitation. I suppose even if there is a Bluetooth 4.0 LE replacement available there may be some .kext changes required. Regardless, baby steps... First things first and that is discovering suitable hardware (-;
Does anyone know where the bluetooth board for a NON ANTI-GLARE model might be found? I'm presuming that I have to lift the logic board to get to it as I can't see anything from the underside.
Hope you can help!
Thanks
John
