Inleiding
Has your MacBook Pro lost its magic touch? Bring it back with a new trackpad.
Wat je nodig hebt
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Remove the following 5 screws securing the mid wall to the upper case:
Three 10.5 mm Phillips screws.
Two 3.7 mm Phillips screws.
Remove the following six screws securing both the right fan and the left fan to the logic board:
Two 3.2 mm Phillips screws.
While holding the trackpad in place with your left hand, fold the top of the trackpad ribbon cable down with your right hand so that it fits through its slot in the upper case.
Feed the ribbon cable through the slot as you push the portion of the trackpad closest to the keyboard out of the upper case.
54 andere personen hebben deze handleiding voltooid.
3 opmerkingen
What size is the tri-wing screwdriver needed to adjust the trackpad on this model?
