Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using both hands, lift and remove the lower case off the upper case.
17 andere personen hebben deze handleiding voltooid.
2 opmerkingen
My only comment is that the 00 phillips does not work it requires the #000. I brought my laptop to the hardware store to purchase the correct phillips.
Does anyone know where to get the Four 3.5 mm Phillips screws? It is extremely difficult to find.
Thx
