Inleiding
This guide will show you how to remove the hard drive cable from your laptop.
Wat je nodig hebt
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
9 andere personen hebben deze handleiding voltooid.
Één opmerking
great explanation I was looking for instruction on YouTube but with no luck thank you so much !!!
