Inleiding
Use this guide to replace the display data cable.
Wat je nodig hebt
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
Deroute the camera data cable from the channel in the optical drive.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
Attach a suction cup along the right side of the front glass panel.
Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
Continue working along the right edge of the front display glass until it is separated from the display.
Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
Attach a suction cup near the upper left corner of the glass display panel.
Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
Attach a suction cup along the left side of the front glass panel.
Continue working along the left edge of the front display glass until it is separated from the display.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
Lift the clutch cover up off the front bezel and set it aside.
Carefully pull the display data cable through the recess located near the left hinge.
7 andere personen hebben deze handleiding voltooid.
