Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a broken left speaker. Replacing the left speaker requires removal of the logic board.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
Salve, per la sostituzione dell’altoparlante destro di un MacBook Pro 15" Unibody Early 2011 si può seguire la stessa procedura? Non trovo la guida specifica.
