Inleiding
Wireless connectivity issues? Use this guide to replace an inoperative AirPort/Bluetooth board.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the camera cable connector straight out of its socket on the logic board.
Peel and remove the piece of EMI tape wrapped around the AirPort/Bluetooth assembly.
82 andere personen hebben deze handleiding voltooid.
22 opmerkingen
does anybody knows if changing this boards changes too the MAC address of the wifi system??
Thanks.
Yes, MAC is associate dand it is unique with each Network interface: wireless or wired.
Hello to the community. I was wondering if i could change my MBP8.2's bluetooth dongle with a one of the newer models (MBP mid 2012 for instance) that support Bluetooth 4.0. Is it possible?
I have a 2011 MBP15. It won't link Bluetooth for Keynote with my new iphone 6+. I understand the reason is I need this upgrade on the MBP.
I'm wondering if doing the upgrade will prevent BT linking between my iPad 2 and my MBP. They can connect now.
Hi everybody! I've change my Airport/Bluetooth board on my MacBook Pro early 2011 cause I think my old board was broken. With the old board Bluetooth works correctly but about wifi board when you look on the icon at the up on right of your monitor it says " no wifi board installed" and inside the wifi icon it appear an 'X'
I buy a new board and after installation the problem was not solved.
Yes, Bluetooth work perfectly and now is 4.0 but I still had the problem of wifi. I can't connect in everyplace my MacBookPro. This is a serious problem for me. Anyone can help me?
