Inleiding
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer & right speaker assembly.
  1. Remove the following ten screws securing the lower case to the upper case:
      • Seven 3 mm Phillips screws.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
    • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
    • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
    • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
  3. Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
  4. Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  5. Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. Tilt the battery back enough to access the battery cable connector.
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
  7. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  8. Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
  9. Disconnect the camera cable by pulling the male end straight away from its socket.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
  10. Peel the camera cable off the adhesive securing it to the optical drive.
    • Peel the camera cable off the adhesive securing it to the optical drive.
  11. This step is only required if you have an anti-glare display. If you have a glossy display, skip this step. Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  12. This step is only required if you have an anti-glare display. Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  13. Use a spudger to pry the optical drive connector straight up off the logic board.
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  14. Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
    • Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
  15. Lift the optical drive from its left edge and pull it out of the computer. When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
    • Lift the optical drive from its left edge and pull it out of the computer.
    • When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
  16. Débranchez le connecteur du câble du lecteur optique de celui-ci.
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
  17. Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board. Peel the hard drive cable up from the channel within the subwoofer and right speaker.
    • Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
    • Peel the hard drive cable up from the channel within the subwoofer and right speaker.
  18. Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  19. Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • Remove the following four screws securing the subwoofer and right speaker to the upper case:
      • Two 3.2 mm Phillips screws.
      • One 2.6 mm Phillips screw.
      • One 5 mm Phillips screw.
  20. Lift the subwoofer and right speaker assembly out of the upper case.
    • Lift the subwoofer and right speaker assembly out of the upper case.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 36
Altijd: 8,419
