Ga door naar hoofdinhoud
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement
Wat je nodig hebt
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement: stap 2, afbeelding 1 van 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Conclusie
26 andere personen hebben deze handleiding voltooid.
Één opmerking
These two little plastic clamps on the upper case that snap on/off the lower case broke. I was looking through the store for replacements but I couldn't find any. Does anyone know where I can get these?
hmalissa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 15,691
