Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a broken trackpad, or to simply remove the trackpad in order to access the battery.
For your safety, discharge your MacBook Pro's battery below 25% before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Wat je nodig hebt
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Peel back any tape covering the battery board data cable connector.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 1.9 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
Remove the bracket.
Use a spudger to pry up the retaining flap on the trackpad ribbon cable's ZIF connector.
9 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Did you manage to buy it somewhere?
Parts list with links to buy them is right at the top of the guide…
Just replaced my trackpad, really easy to do! Thanks again guys!
