Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. heat the logo baffle(用吹风机小心的加热LOGO挡板) use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎) use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
    • heat the logo baffle(用吹风机小心的加热LOGO挡板)
    • use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
  2. Put double-sided tape on the back of the baffle(在新的挡板后面贴上双面胶带)
    • Put double-sided tape on the back of the baffle(在新的挡板后面贴上双面胶带)
  3. Install the baffle 把挡板安装到原来的位置
    • Install the baffle 把挡板安装到原来的位置
Conclusie
当重新组装你的设备时,请按照说明的相反顺序进行操作。
11 andere personen hebben deze handleiding voltooid.
n0vem
580 Reputatie
1 Handleiding geschreven
57 Opmerkingen
I didn't manage to get it off without breaking it so had to order a new one. which was a peal and stick.
mayer - Antwoord
I don’t understand, when do you need to remove this if it’s not broken already? Are there components underneath that can be replaced/fixed?
Ted -
I have a hairline at the logo baffle if i do not replace it will my screen get harmed?
Please reply ASAP?
Honey - Antwoord
can u upload the photo, than I can tell u
n0vem -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 367
Altijd: 30,567
