Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
For blowing out the dirt you will need a bellow as they are used for camera cleaning.
Use the bellow to clean your keyboard. Otherwise you might end up getting even more dirt into the key after removing the cap.
Slide the card into the gap between upper edge of the key cap and casing. (For the small "arrow up" key it's on the right side, for the "arrow down" key it's on the left side, for the "return" key it's on the left side.)
Gently lever up until you hear two clicks (or up to four for longer keys like shift or space bar). They indicate that the cap is released on both notches.
While lifted up, take the key cap with your fingers and gently pull it towards the display.
17 andere personen hebben deze handleiding voltooid.
8 opmerkingen
Does the replacement key come with the transparent plastic cover that goes over white butterfly mechanism? When this is damaged, is it possible to replace the key so it functions as new? Thanks for info.
I haven’t bought a replacement key yet so I can’t guarantee this 100%, but I think, that these transparent “sockets” for the white butterfly mechanism are part of the key cap. So I’d guess: Yes, the transparent part is integrated in the replacement key.
If you buy one, I’d be happy if you’d let me know whether this is true! :)
It depends on what’s damaged. Most likely it’s not the key cap but the white butterfly mechanism itself. If you replace that it should work as new. But I recommend to try cleaning as in the instructions above first – for me and my friends keyboard issues with these models always came down to dirt in the mechanism.
In theory, the transparent clips shouldn’t really affect the function of the key. It rather holds the key cap in place, so if these are broken, it is more likely that your key caps don’t stay in place (e. g. are lifted up or slightly turned when typing).
I picked up one of these kits from www.laptop-keys.com and they were able to provide the key cap, plastic scissor mechanism and that plastic part the sits underneath. Along with this guide, I was able to restore my MacBook keyboard back to new. Thanks for the great write-up!
Thanks for sharing this! They even seem to ship internationally for about $3, that is really useful!
