Ga door naar hoofdinhoud
MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement, Logic Board Assembly: stap 1, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement, Logic Board Assembly: stap 1, afbeelding 2 van 2
    • Remove the two 2.2 mm Torx T5 screws securing the touchpad cable connector cover to the logic board.
    • Remove the cover.
  2. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 2, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 2, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 2, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the touchpad cable connector from its socket in the logic board.
    • Slightly twisting the flat end of a spudger is an easy way to pry up the cable connector from these types of sockets.
    • Be careful to only pry up against the connector, and not the logic board socket.
  3. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove a small rubber cap off the screw at the end of the heat sink.
  4. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the following six screws securing the logic board assembly to the upper case.
    • One 3.8 mm T5 Torx screw
    • Two 5.7 mm T5 Torx screws
    • One 5.6 mm T5 Torx screw (this one is silver and has a taller head than the others)
    • One 2.6 mm T5 Torx screw
    • One 3.2 mm T5 Torx screw
    • On reassembly, start all six screws but do not tighten any of them. Move the logic board around until all of the screws are centered in their holes and the ports are lined up with their openings in the side of the upper case. Then tighten all of the screws.
  5. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 5, afbeelding 1 van 1
    • The following steps will detail disconnecting these six connectors. Be sure to read each step, as these connectors come in different styles that disconnect differently.
    • Microphone cable
    • Left speaker cable
    • Keyboard data cable
    • Right speaker cable
    • Keyboard backlight cable
    • Display data cable
    • On reassembly, check to make sure all of these connectors are connected and fully seated in their sockets.
  6. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 6, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 6, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 6, afbeelding 3 van 3
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket, parallel to the logic board.
  7. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 7, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 7, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 7, afbeelding 3 van 3
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Be sure to pry on the cable connector and not on the socket on the logic board. Prying on the socket may cause it to separate from the logic board.
    • Gently fold the cable up and out of the way of the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 8, afbeelding 2 van 2
    • Peel back the tape covering the top of the keyboard data cable connector.
  9. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 9, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 9, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 9, afbeelding 3 van 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard data cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the keyboard data cable out of its ZIF socket. Be sure to pull parallel to the logic board, and not straight up.
  10. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 10, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 10, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 10, afbeelding 3 van 3
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board.
  11. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 11, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 11, afbeelding 2 van 2
    • Use the point of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
  12. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 12, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 12, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the MagSafe 2 power port side of the computer.
  13. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 13, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 13, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 13, afbeelding 3 van 3
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    • Do not touch the contacts on the data connector or its socket with your fingers or any tools, as you may deposit oils or damage the pins.
    • Gently bend the display data cable toward the display hinge, to expose the screws on the MagSafe 2 board.
  14. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 14, afbeelding 1 van 1
    • Remove the two 4.0 mm T5 Torx screws from the MagSafe 2 board.
  15. MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 15, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 15, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 Logic Board Assembly Replacement: stap 15, afbeelding 3 van 3
    • Lift and pull the entire logic board assembly away from the wall of the upper case.
    • When reassembling, be sure to line up the ports with their cutouts in the upper case.
Conclusie
Andrew Optimus Goldheart
502.825 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 872
