Ga door naar hoofdinhoud
MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
Wat je nodig hebt
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 2, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 2, afbeelding 2 van 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 3, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 3, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 3, afbeelding 3 van 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: stap 4, afbeelding 1 van 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 5, afbeelding 1 van 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 5, afbeelding 2 van 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 5, afbeelding 3 van 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): stap 6, afbeelding 1 van 1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 7, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 7, afbeelding 2 van 2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 8, afbeelding 2 van 2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: stap 9, afbeelding 1 van 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
502.846 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 102
Altijd: 8,959
