Inleiding
Have your MacBook Pro feet seen better days? Use this guide to give your Mid 2014 MacBook Pro a fresh set of feet.
Remove the following pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
