Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Have your MacBook Pro feet seen better days? Use this guide to give your Mid 2012 MacBook Pro a fresh set of feet.
  1. Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace. Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  4. Remove any broken or damaged feet. If the foot you are replacing is still intact, you can use your tweezers  push it out from the inside.
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  5. Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  6. Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  7. Peel a replacement foot from the plastic backing.
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  8. Align the new foot inside the cavity. Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad. Lay the foot down while keeping it properly aligned.
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  9. Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb. Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Taylor Dixon
44.172 Reputatie
91 handleidingen geschreven
iFixit Lid van iFixit
Community
135 Leden
14.979 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 137
Altijd: 5,324
