Inleiding
This motherboard includes all ports on the right side.
Wat je nodig hebt
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Remove the following 16 screws, moving cables as necessary:
One 4.4 mm black Phillips screw to the right of the RAM slot.
Nine 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
Peel up the iSight and inverter board cables from above the left fan.
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
Place the fan above the Airport card. It is not necessary to entirely remove the fan from the computer.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connector.
53 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Buying the part, it says that thermal paste is needed for installation. Where?
Thermal paste is needed to transfer heat from the Nvidia GPU and the CPUs to the heat spreader bar which is located below the motherboard. It transfers heat from the CPUs to the fans.
The final part says to just follow the steps in reverse order to reassemble--that isn't quite enough information. It is critical *not* to snug or overtighten the memory door screws from step 2. The screws pass to the bottom of the keyboard, and the keyboard is made of a light material that deforms easily. If you overtighten the screws it will bend the keyboard out of shape and the spacebar will not work properly.
After installing the screws on the memory door, then test that the space bar goes down and back up properly. If it doesn't back the screws out and try again. Do not proceed with the rest of reassembly if the keyboard is not working.
I totally second this!
