Inleiding
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
Wat je nodig hebt
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the iSight, inverter, and left fan cables from the logic board.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Één andere persoon heeft deze handleiding voltooid.
