Inleiding
Use this guide to replace a cracked or malfunctioning display assembly on a MacBook Pro 15" Core Duo Model A1150. The display assembly is the component responsible for visual output. In this device, the display assembly includes the inverter, Airport antennas, hinges, and casing.
If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
No special tools or skills are required to complete this repair procedure.
Onderdelen
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Disconnect the two antenna cables attached to the Airport Extreme card.
25 andere personen hebben deze handleiding voltooid.
