Inleiding
This motherboard includes all ports on the right side.
Wat je nodig hebt
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical Phillips screws from the memory door.
Tip for new players - print this guide, then use Sello tape to tape the screws from each step on the picture. Keeps them all organised and easy to know which screws belong to which step when putting it all back together
Thanks a lot for this great advice. I followed it, and it turned out to be very useful and practical.
In regard to the incredible amount of TINY screws, get an Ice Cube Tray or something with AT LEAST 8 compartments, then, when taking out the screws, mark EACH compartment with the step # and how many screws that were taken out, and used for THAT STEP (such as Step # 3 = 4 of 4 screws. Label EACH compartment, and keep them in line of each step. When it comes time to put everything back together, just reverse your Ice Cube Tray, and follow the Steps in Reverse!
As far as marking each compartment, try these POST IT PENS!!!
http://www.staples.com/Post-it-Flag-Ball...
GOOD LUCK! Take your time, it's not as difficult as it seems!
JerseyJeepGurl
An ice cube tray is definitely the way to go!
This guide helped me to remove the keyboard on my MBP, but it doesn't take you further to take the keyboard apart. If you REALLY want to look inside the keyboard, you'll need to remove additional phillips screws (10), and carefully remove the inner plastic/clear layers inside the keyboard.
I did this to look for physical damage inside the keyboard and noticed that the black plastic? sheet was torn on my letter 'v', which was one of the keys not working. I did not see any physical sign anywhere else on the keyboard, though.
So, after pulling the defective keyboard away and installing the new one purchased from iFixit, putting everything back together is not too difficult, just reverse.
One thing, though: Check and double-check before you tighten the case screws to make sure your keyboard backlight is working. I noticed I had forgotten to plug it in, luckily for me before I put all the screws on the case.
To avoid losing any screws, print this guide and use clear tape to tape the screws next to the step. Use double-tape to avoid tearing or one of the tiny screws from falling out.
Good luck!
Thanks iFixit for helping me replace my MBP's keyboard!
Worked perfect on my 4,1 mbp. Took ~15 min.
I don't see a boost in speed... or is just me?
I used 500 GB 7200 RPM Seagate SATA Hard Drive model ST9500420AS.
(if has a G letter at the end (ASG) is the one with built in shock protection who conflict sometimes with the mac own G protection).
This guide was awesome. I used JerseyJeepGurl's suggestion and used an egg carton, numbering each cavity as a step in the guide. So for a step that had me remove 3 different kinds of screws, I had a cavity for each, numbered: 1a, 1b, 1c and wrote a,b,c on the guide itself next to each bullet point in the step. It was awesome.
I guess that before starting I overlooked what a T6 torx actually was. I started this process at 8pm and realized right away that I did not have a set that small and of course all stores were closing. Lowes actually had an awesome fine torx driver set for only 7 bucks!
So that you fixit.
Citaat van tech4eleven:
So that you fixit.
Thank you everybody for "thanking me" on the compartment advice! Also, just about ANY Auto parts store will have a set of Torx Screw drivers, in a handy little set, that is all together. Good luck everybody,,remember,TAKE YOUR TIME, BREATH, AND DON'T GET FRUSTRATED!!! (STEALING ADVICE FROM PEARL JAM,,BREATH,JUST BREATH),,,,AND YOU'LL BE ABLE TO DO IT YOURSELF!
JJG
Citaat van JerseyJeepGurl:
JerseyJeepGurl
Citaat van Michael Fredrickson:
I get a piece of "corrugated" cardboard and draw an outline of the laptop and all the "compartments" that are accessed. When you take a screw out simply punch it threw top layer of the cardboard exactly where it goes. Multiple compartments - just draw another diagram on the cardboard. Voila!
I just finished replacing my hard drive following these instructions and they were perfect. The only minor complication involved the ribbon cable connecting to the sleep light and IR sensor connectors. The entire cable was tightly glued to the hard drive. But I got it loose with 10 minutes of gentle prying with a spudger.
To keep track of the screws I just sketched an outline of the bottom panel, taped the screws in the right places and numbered them with the step numbers.
I just used that Glad Press' N Seal. I just cut a 4 in piece, cut slits in it to about half way, Put the screws on there, and fold the pieces over the screws. You can number them, i just kept track of them. Also, you might not need that much, i just cut that much just to be safe.
I use magnet
I use the magnet that close the refigerator door.
The screws are put on the magnet, so it didnot fall from the table.
i am french so sorry for my english
Madoc -
Just another idea for a container for all the little screws: pillbox. I got one for about $1.00 at the store with 14 compartments.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the four 3.2 mm Phillips screws on the port side of the computer.
"port side of the computer" should read "starboard side". It's on the right-hand side when the computer is positioned normally in front of you.
Port side as in I/O port side, as in the side that has the FireWire and ethernet ports. This is a MacBook, not a sailboat ;)
Maybe I'm too used to running flight simulators on my Macs. But to us sailors or pilots, it would perhaps be clearer if the instructions mentioned "I/O port side" as Andrew did above.
Honestly, it never crossed my mind that 'port' refered to in/out…
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
In my machine the screw closest to the power connector had a slightly thicker head, and would not sit flush, upon reassembly, unless it was returned to the same hole.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
I had already done this once and now have a larger SSD to put in and cannot get past this step as the back just will not pop off. In fact- the front comes off fine but the back, where you cannot get the spudger, is "glued" or wedged solid. I suspect that the rear screw tabs have jammed. :(
I would not rock the case up and back. There are 4 plastic connectors that need to come loose, start on the left side with a spudger about a quarter of the distance from the edge and pop them up from left to right, one by one.
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Kudos for this fantastic walk-through of replacing the hard drive. I just swapped in a new SSD and it was a piece of cake!
On Step 10, I tried just propping up the keyboard and leaving it connected to the logic board. It worked for a while but eventually the ribbon popped off. Luckily it wasn't damaged and it's super easy to replace.
Same happened to me. No damage here either. :-)
Since there is the ONE cable going from the top keyboard/touchpad assembly to the motherboard, you need to be careful lifting it up and removing it.
Start at the front of the laptop, using a spudger to widen the gap so you can see inside where the ribbon cable attaches.
When re-assembling, use a couple of spudgers to prop up the keyboard/touchpad assembly and hold it in place. Re-connect the cable, then starting from the rear, lower the assembly into place.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the following 4 screws:
Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
One 4.7 mm silver T6 Torx screw from the top left corner of the drive
One 6.2 mm black Phillips screw at the top right corner of the drive.
Regarding the following instruction: -
Be aware there are two of these on the bottom (if the slot is facing you) screws close to each other, one is for the actual drive assembly itself and the other is attaching the drive to the Mac. Beware you choose the correct one.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
On putting this back together, I'm finding the small upper cable that presumably is battery monitoring (lower left hand corning of the picture) is not staying in place (I'm using the one that shipped with the lower tray, not the original). I'm thinking either some of the anti-static tape, or a rebending of the wires to help apply continuous pressure. I had to take the top off one already as a consequence of this, as it wouldn't power-up on battery alone, and the next day, the problem appears to have returned.
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
In the diagram, the yellow circle and the orange next to it should be swapped. The black screw won't even grasp the threads in the indicated hole.
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connector.
48 andere personen hebben deze handleiding voltooid.
7 opmerkingen
When putting the card back in place, take care that the thermal sensor cables coming from the lower case be over the card, and that the black spacers near the screen be in place.
As well as the battery cable !
Will i lose any of my files after doing this procedure?
Thank you! Nice tutorial for thermal paste replacement. 1h for me.
Years ago, I had to return/replace this type of a battery several times because of erratic behavior in the laptop. Suddenly I had one that lasted for 5 years before not taking any charge anymore. So, I'm going to order a new one hopefully without having to restart the return charade BECAUSE:
I observed that the battery's CONTACTs are unreliably INTERMITTENT. So far, it helped for a while moving it in and out in order to chafe the contacts' surfaces against each other.
moise - Antwoord
