Inleiding
This motherboard includes all ports on the right side.
Wat je nodig hebt
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connector.
48 andere personen hebben deze handleiding voltooid.
7 opmerkingen
When putting the card back in place, take care that the thermal sensor cables coming from the lower case be over the card, and that the black spacers near the screen be in place.
As well as the battery cable !
Will i lose any of my files after doing this procedure?
