Inleiding
你可以安装厚度最大为9.5mm的硬盘。
Wat je nodig hebt
要重新组装您的设备,请按照本指南的相反顺序进行操作。
580 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Leon赵国鑫 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
20 opmerkingen
If your button to open mac is hard to use after you re-assembled the computer, check to see if the proper length screws were reinstalled. I had that problem and I switched the 2 screws. One was a tad longer. The longer one when screwed in, interferred with the button function.
Definitely NOT true for MY Mac. Both screws are absolutely identical. Still I had this issue. :-(
Turned out that if I screw them in real tight the issue will occur. If I turn back the screws about 180 degrees (i. e. if I loosen them) the problem disappears.
