Ga door naar hoofdinhoud
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je MacBook Pro 14" Late 2023 (M3 Pro and M3 Max) te repareren, gebruik onze reparatiehandleidingen.
  1. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: stap 1, afbeelding 1 van 2 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: stap 1, afbeelding 2 van 2
    • Apple APL1203/339S01320 M3 Pro 12-core applications processor w/ 18 GB memory
    • Apple APL109H/343S00652 power management
    • Apple APL109H/343S00653 power management
    • Kioxia K5A3U08299 128 GB NAND flash
    • Texas Instruments SN25A12 USB type-C controller
    • Likely Parade Technologies PS190 DisplayPort-to-HDMI converter
    • Likely Apple U0KSS1-L2 ThunderBolt controller
  2. MacBook Pro 14" Late 2023 M3 Pro Chip ID: stap 2, afbeelding 1 van 1
    • Genesys Logic GL9755A card reader controller
    • Apple 338S00600-A0 power management
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Winbond W25Q80DVUXIE 1 MB serial NOR flash memory
    • Renesas RAA225702B DC-DC converter
    • Analog Devices LT8642EV-1 10 A / 18 V synchronous step-down regulator
    • Texas Instruments TPS62180 6 A synchronous buck converter
  3. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: stap 3, afbeelding 1 van 2 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: stap 3, afbeelding 2 van 2
    • Renesas RAA489901A5 battery charger
    • Texas Instruments SN012776B0 audio amplifier
    • Kioxia K5A3UN0975 128 GB NAND flash
    • Apple APL109G/343S00649 power management
    • Apple APL109G/343S00650 power management
    • Cirrus Logic CS42L84A audio codec
  4. MacBook Pro 14" Late 2023 M3 Pro Chip ID: stap 4, afbeelding 1 van 1
    • Winbond W25Q64NEXGIG 8 MB serial NOR flash memory
    • Winbond W25X40CLUXIG 4 Mb serial NOR flash memory
    • Texas Instruments LP8548B1 LED backlight driver
    • Renesas RAA209100B1 DC-DC converter
    • Renesas RAAxxx501C DC-DC converter
    • Texas Instruments REF3325 2.5 V voltage reference
  5. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Connectivity: stap 5, afbeelding 1 van 1
    • Likely USI 339S01093 WiFi/Bluetooth module
  6. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Sensors: stap 6, afbeelding 1 van 1
    • Likely Bosch Sensortec accelerometer and gyroscope
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 109
Afgelopen 30 dagen: 566
Altijd: 8,244
