Inleiding
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Video overzicht
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
769 andere personen hebben deze handleiding voltooid.
48 opmerkingen
I thought these batteries couldn't be replaced.
These batteries are built to the same spec as OEM (Apple)
They are just not "user friendly" to replace like most devices are, the price we pay for pretty devices.
This guide is excellent and now I know I need 1 more tool before I do this myself. I need that tri-wing screwdriver.
Clear, well written instructions, thank you! (But yes, a line about take off shoes and socks and ground yourself is helpful. )
