Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Verwijder de volgende tien schroeven:
Drie 14.4 mm lange Phillips #00 schroeven
Drie 3.5 mm lange Phillips #00 schroeven
Vier 3.5 mm lange geschouderde Phillips #00 schroeven
Gebruik de voor- of achterkant van een spudger om de batterijaansluiting uit het contact op het moederbord omhoog te wrikken.
Deze stap is niet vertaald. Help het te vertalen
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector above the optical drive.
Use the tip of a spudger to lift the AirPort/Bluetooth connector off of its socket on the AirPort/Bluetooth board.
Remove the AirPort/Bluetooth cable from the machine.
39 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Had the most strange errors with a wi-fi with errors for long. Send the computer both to apple and to insurance without success.
Now I'm on my own on my wifi first broke saying "No hardware installed", Bluetooth was still working in the beginning thou. After checking here I ordered a new cable and everything was fixed in under 30 minutes.
The cable I bought was names -A in the end instead of -02 but everything works just fine so far. According to the seller they are the same. Thanks for help solving this strange problem in a simple way!
I've just made this and all my connectivity problems are now gone!
Thanks iFixit team :)
Fixed my wifi connectivity problems! However it did not fix my bluetooth connection. I did have a problem where the wire was actually disconnected from the actual connection and the connection was stuck in the socket. I got the connection out by using an Xacto blade on the side to pry it out. Then I followed all the other steps and it worked fine! I also disconnected the battery and had no problems reconnecting it.
