Ga door naar hoofdinhoud
MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement, Remove the lower case screws: stap 1, afbeelding 1 van 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement, Lift the lower case away: stap 2, afbeelding 1 van 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Conclusie
43 andere personen hebben deze handleiding voltooid.
Één opmerking
Those are actually not seven identical 3 mm screws. The screw located at the ventilation side next to the three 13.5 mm screws does not have a shaft as compared to the other six 3 mm screws.
glaubitz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 36
Altijd: 39,091
