Inleiding
Use this guide to replace the LCD rather than the entire display assembly.
Wat je nodig hebt
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
Attach a suction cup along the right side of the front glass panel.
Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
Continue working along the right edge of the front display glass until it is separated from the display.
Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
Attach a suction cup near the upper left corner of the glass display panel.
Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
Use a heat gun or hair dryer to soften the adhesive under the black strip along the left side of the front glass panel.
Attach a suction cup along the left side of the front glass panel.
Continue working along the left edge of the front display glass until it is separated from the display.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
Lift the clutch cover up off the front bezel and set it aside.
De-route the display data cable from its retaining bracket near the lower left edge of the display.
79 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
All I can say is THANKS! I was able to replace my daughters display, the bottom aluminum panel and to remove the dents from the top aluminum panel. Without your guide, I doubt I ever could have done this. You saved me hundreds! Your spudger tool was worth its weight in gold....till I used it to break the glass front panel...sigh. Still, I'll use that hundreds of times from now on.
==Step 17==
It is extremely critical that when attaching the suction cup to FIRST LIFT THE LEVER ABOUT HALF WAY before attaching to the glass in order to only apply about half the suction the tool is capable of applying!! Lift the lever half way. Set into position on glass. Lift the rest of the way to apply about half of the suction cup's potential suction. Failure to do this WILL result in circular break around the suction cup!
This was extremely helpful. I am a junior in high school who was issued a Mac for class. I am one of those anti-Apple people, so I get easily frustrated with them and tend to beat them up a bit. Consequently, I broke it. Being low on funds, I couldn't afford the repair costs, let alone had the nerve to own up to my actions and tell the teacher about it. SO....after staying up an extra couple hours researching the problem, I discovered this and decided to give it a try. Despite already being somewhat tech savvy, I found this resource very helpful, even more so after re-reading it and watching a couple how-to videos. The problem was fixed in no time.
Lets just say, thanks to this site, the school never found out that I broke the laptop. :)
GREAT GUIDE! Thanks!
I had a laser targeted infrared thermometer for another project ($25 at local hardware store) and found the screen cover adhesive softened nicely at top and sides at 140-145F. I used a hairdryer on high setting.
I found with the top edge and both side edges lifted free of the adhesive in earlier stages, the bottom edge lifted easily at 100-105F. (I had package taped the screen as it had cracks, being sure the tape laid flat so sunction would form in the early steps.
NOTE THE MAXIMUM SPECiIFIED NONOPERATING TEMPERATURE IS LISTED BY APPLE AT 113F for the 2010 MBP 13”. Separating the bottom and top cases allows the keyboard and all the other goodies in the lower case to rest comfortably away from the heat.
One or two very thin flexible pry tools like iSesame (inexpensive online) worked well once the upper corner was lifted with a suction cup
This guide is the same of MacBook Pro 13 unibody 2012?
