Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Verwijder de volgende 10 schroeven uit de onderste behuizing van de MacBook Pro 13" Unibody:
Zeven 3 mm lange kruiskopschroeven.
Drie 13.5 mm lange kruiskopschroeven.
Til de voorkant onderste behuizing iets omhoog en duw de behuizing richting de achterkant van de laptop om de behuizing volledig los te krijgen.
Deze stap is niet vertaald. Help het te vertalen
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use a spudger to pry up the fan connector out of its socket on the logic board.
Remove the following three screws:
One 7 mm T6 Torx screw
Two 5.4 mm T6 Torx screws
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away parallel to the board.
Remove the following two screws securing the display data cable bracket to the upper case:
One 8.6 mm Phillips
One 5.6 mm Phillips
Lift the display data cable bracket out of the upper case.
Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
Use your spudger to slide the keyboard ribbon cable out of its socket.
Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
Remove the following screws:
Two 7 mm T6 Torx screws from the DC-In board
Five 3.3 mm T6 Torx screws
Two 4 mm T6 Torx screws
Remove the following Tri-point screws securing the battery to the upper case:
One 5.5 mm Tri-point screw
One 13.5 mm Tri-point screw
Lift the battery out of the upper case.
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
Remove the four 8.5 mm Phillips screws securing the heat sink to the logic board.
62 andere personen hebben deze handleiding voltooid.
5 opmerkingen
I enjoyed the process and the fixit guides are great. But I had one potentially fatal issue with the heat sink replacement guide (to apply thermal paste ). The guide says to "Pull the display data cable connector straight away from its socket" when it should say "gently pull it to the right in order to dislodge it from the socket, never pull upwards". I pulled it upwards because I did not realize that it was a "sideways" socket, and almost broke the socket and had a blank screen on startup (gently righting the bent socket with a tweezers fixed it).
Very glad you're able to fix the connector :)
Thank you for this write up. I was able to change out a bad logic board on my mid 2010 macbook pro that my ex wife had ruined with a spill of a soft drink. The heat sink on the new-used logic board was in worse shape than the original heat sink, so I had to swap them out. Wouldn’t have been able to do that without this guide. Once again, many thanks on helping to get new life into my 10 year old macbook pro :D
having difficulties after changing my thermal paste, unable to get the MacBook to boot up. Tinkered around a bit and it booted up for one go then a few keys were not working so I had to reconnect the cable again then the laptop went off again. Please help.
Last night, I did the thermal paste on an Early 2011, 17" and had no trouble. Now, I just did the thermal paste for this one, Mid 2010, 13", but the machine won't turn back on.
The battery indicator works on the outside of the machine works. I tried connecting the magsafe and its light did not turn on. I took the bottom case off, looked at the connectors, then tried the magsafe again. Now the magsafe seems to be working properly (green at first, then amber). I tried resetting SMC, got nothing.
I'm wondering if I damaged the hard drive cable. Would that cause the machine to be unresponsive? Is it safe to say the logic board is fine if the battery indicator is working?
Any other ideas? Thank you
