Ga door naar hoofdinhoud
MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Remove the lower case screws: stap 1, afbeelding 1 van 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Antwoord
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Antwoord
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Antwoord
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Antwoord
  2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Lift the lower case away: stap 2, afbeelding 1 van 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Antwoord
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Antwoord
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Battery: stap 3, afbeelding 1 van 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    Citaat van gansodesoya:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Antwoord
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Antwoord
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Antwoord
  4. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Display: stap 4, afbeelding 1 van 1
    • Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
    • Pry up from beneath the wires.
    Mine had a small piece of insulating material on top of the connector. By removing that first, I could then pry up the connector with less stress on the cable.
    istlota - Antwoord
    Great tip! Thanks.
    juliet - Antwoord
  5. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Make sure to pull the connector parallel to the face of the logic board and toward the optical drive, not straight up from its socket.
  6. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 6, afbeelding 1 van 1
    • De-route the camera data cable from the channel in the optical drive.
    for easy dismantle, just remove 2 screw of subwoofer
    Mohamad Faizal Sharudin - Antwoord
  7. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 7, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 7, afbeelding 2 van 2
    • Remove the following screws:
    • Two 10 mm Phillips screws
    • One 3.8 mm Phillips screw
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
  8. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 8, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 8, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 8, afbeelding 3 van 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
  9. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 9, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 9, afbeelding 2 van 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 8.6 mm Phillips screw
    • One 5.6 mm Phillips screw
    • Lift the display data cable bracket out of the upper case.
  10. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 10, afbeelding 1 van 1
    • If present, remove the small strip of foam tape stuck to the display screws near the display data cable.
  11. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 11, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 11, afbeelding 2 van 2
    • Remove the two outer 6.5 mm T8 Torx screws securing each of the two display brackets to the upper case (4 screws total).
    You may have to lift/remove a foam tape on the left side as well
    Sebastien CHAPUIS - Antwoord
  12. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 12, afbeelding 1 van 1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining 6.5 mm T8 Torx screw from the lower display bracket.
  13. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 13, afbeelding 1 van 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
    When reassembling, Careful not to drop your screw, or it may get stuck to the (magnetic) power adapter port. Oops!
    Save yourself some time and don't drop it!
    rowdyferret - Antwoord
  14. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 14, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 14, afbeelding 2 van 2
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    Make sure you make a 90 degree angle between the keyboard and the display before taking out the screws. If you have less than a 90, you will never get it apart due to the upper display bracket shape. It has to be at the right angle or it won't come out.
    mastover - Antwoord
    I place it over keyboard side down hanging over a table. This way I know it's at 90 degrees and it also makes it easier to take it off.
    Nick - Antwoord
  15. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 15, afbeelding 1 van 1
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
    As mentioned in the previous step, place it keyboard side down with the edge hanging over a table. This way it's at 90 degrees and it makes it easier to align and get the screws in.
    Josh - Antwoord
  16. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Front Display Glass: stap 16, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Front Display Glass: stap 16, afbeelding 2 van 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
    Heating rubber strip it becomes glossy You can turn it to matte using ultrafine sandpaper (very ultrafine!!!) P2500
    Silvio - Antwoord
    Great piece of advice. Thank you!
    Brian -
    With a lot of heating, for me, it was very hard to get the glass to separate from the case. I had better luck starting from the bottom right as I could grip better onto the case. Three mistakes I made:
    1. Once I got the glass separated, I probably didn't heat sufficiently as I was going around and the glass broke. That made the rest of the procedure miserable. Lesson: pull very gently.
    2. I must have touched one of the tiny bits of glass that fell on the LCD and it scratched the actual screen. :-(. Lesson: vacuum the pieces as you go and be very careful when touching the LCD.
    3. I somehow overheated the LCD screen at the top left and right corners and now the display is all wonky and faded at the corners. Not sure what the lesson is here.
    Athanassios Diacakis - Antwoord
    First, if using a hair dryer, what setting should that be operated at? It would be much cooler than the heat gun, right?
    Second, the iFixit basic set comes with a small, clear suction cup. Would that be sufficient for this project, or does it require the stronger pull of the other cups?
    Finally, must I reapply adhesive to the case when replacing the glass? Does the original remain tacky and re-bond on assembly?
    contact - Antwoord
    It's been a while since you asked, but since no one answered and someone else may have the same questions:
    Hair dryers vary a lot, depending on wattage. I would start on low or med, and work my way up to high if necessary. I'd keep the fan on the lowest setting.
    The little suction cup is for removing screens like the iMac, which just uses magnets, and possibly an iPad or iPhone. I would not want to use that for this project, get something about 2" wide with a decent handle.
    The screen should have the double sided glue tape already applied, just remove the backing. I wouldn't get glass that doesn't have the tape on it, big waste of time with little savings in cost.
    Jeff Kamis
    maccentric -
    All I can say for this is don't be tempted to hold the heat gun too close. I ended up burning my LCD the first time I did it and having to replace that when all I was looking to do was replace the cable. I got the glass off holding it about 4/5 inches from the screen and being patient (it took about 5/10 minutes in the end).
    Nick - Antwoord
    The tape is very sticky and the glass is very fragile but at the same time fairly flexible.....I ended up breaking the glass ans it turned out to be a mess picking up the shards....but in the end a new glass is not too costly. the implication is that heating melts the glue but it is really just double stick tape.....there are some "youtube" videos that are worth a look but I would suggest using guitar picks and not a putty knife which creates a point load that breaks the glass....wear safety glasses!!
    brian62 - Antwoord
    Be ready to replace the glass (good thing mine was already broken, I ordered one). Wear surgery gloves and protective glasses. Trust your nose, if it smell melted plastic, it’s a good clue to stop the heat.
    It's more easy to do this step before removing the LCD. You have more control of the LCD and is more easy to remove the Glass.
    Felix - Antwoord
    If you have a glass cover that is severely cracked then the heating gun and suction cup procedure really doesn’t work. Suction cups won’t hold and the already broken glass doesn’t lift. Here’s what I did that made the job easier. Using 2 inch wide transparent packing tape I laid it along the perimeter of the display but not covering the rubber edge. Then I used a 1/4 inch wood carving tool and very carefully removed the glass and 2 sided tape around the metal border. Use as your guide picture 2 in this step that shows where the camera and cable is located. Where the camera is located in the top center the 2 sided tape isn’t located so you can easily lift the glass. The camera cable runs up the right side in a trough in the metal border so when lifting the tape and glass in this area just keep the sharp end flat and it is wide enough it won’t dip into the trough and damage the cable. The tape was very helpful because it kept the glass from splintering and going everywhere.
    joe lochner - Antwoord
  17. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 17, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 17, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 17, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Koop
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
  18. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 18, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 18, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 18, afbeelding 3 van 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  19. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 19, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 19, afbeelding 2 van 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
    I ended up breaking my glass panel due to using the spudger. I think if you use something more like a small putty knife you will do better. The spudger puts a lot of pressure in a small spot while the putty knife would put a little pressure over a larger area. Also, if you do break the glass, be sure to get ALL of the broken bits off before putting the new one on. Also, watch out for those broken bits as they tend to penetrate skin quite easily, and stay there for days!
    mastover - Antwoord
  20. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 20, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 20, afbeelding 2 van 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  21. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 21, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 21, afbeelding 2 van 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  22. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 22, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 22, afbeelding 2 van 2
    • Use a heat gun or hair dryer to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  23. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 23, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 23, afbeelding 2 van 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
  24. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 24, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 24, afbeelding 2 van 2
    • Skip this step if you're reusing the original glass.
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  25. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 25, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 25, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: stap 25, afbeelding 3 van 3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
Conclusie
70 andere personen hebben deze handleiding voltooid.
7 opmerkingen
If the glass you are replacing is badly broken the suction cups may not attach. I ended up having to remove the glass piece by piece and the process took a couple of hours. You should wear protective glasses and wear rubber gloves to prevent getting finger prints on the lcd screen. Although this was a time consuming process I was successful removing the broken glass and replacing without any issues.
davidstewart - Antwoord
I actually had the same problem as David but in 2 hrs I had removed all of the glass pieces. Now my MB looks like it had never fallen!
Thanks ifixit, you saved me €450.
PS. the parts were in Belgium in 3.5 days, I was amazed at how fast it was.
matthiasvanaverbeke - Antwoord
I found it more convenient to lay the computer keyboard-down on a table with the display hanging over the edge while performing steps 11–15.
The need for a hot air gun greatly increases the possibility of damaging various parts of the laptop [keyboard, airport antenna assembly, clutch cover, strip around the screen, even the screen, possibly the two brackets --- which allow the top and bottom cases to fold together for the clamshell effect --- which are not metal but rather plastic painted to look like metal]. Some people have spent the extra money to buy a special hot air gun with a small focused spout. But, the smarter, simpler, approach is to forget about replacing just the front glass cover and replace the entire display assembly instead. iFixIt is currently out of stock of entire display assemblies, but you can find them elsewhere on the Net for $100 or less. Instead of buying iFixIt's glass cover and recommended tools, I could have bought the entire display assembly for about the same money.
istlota - Antwoord
Hello, what kind of glue should I use to fix the new new glass on?
kekko690 - Antwoord
The thickness / coverage of the area available to put the adhesive is plentiful which allows you to use more adhesive than you need. Anyway what I use is red double sided tape as it's adhesive strength is very good and the thickness is good to use in this case. It's called 'PET red double sided transparent tape'.
I think iFixit sells rolls of them which aren't really expensive at all.
Ben -
Followed this, step by step, using a mid power hair dryer as the heat source. No difficulties what so ever. Everything came apart as expected, leaving the cables in the clamshell and not stuck to the glass on removal. Paid attention to getting the glass and the LCD as clean as possible before re assembly. Now the cracked screen that was in six parts is replaced with a replacement glass and everything works as it should and no dirt or debris between the glass or LCD. I purposely used a hairdryer as heat guns are notoriously powerful, and just took my time with the glass removal. No heat destroyed rubber seal or condensation on removal. Patience is the name of the game with this repair...
Mike - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 54
Altijd: 116,190
