Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Verwijder de volgende 10 schroeven uit de onderste behuizing van de MacBook Pro 13" Unibody:
Zeven 3 mm lange kruiskopschroeven.
Drie 13.5 mm lange kruiskopschroeven.
Til de voorkant onderste behuizing iets omhoog en duw de behuizing richting de achterkant van de laptop om de behuizing volledig los te krijgen.
Deze stap is niet vertaald. Help het te vertalen
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Using the flat end of a spudger, gently pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
Lift the subwoofer off the optical drive, and set it above the computer.
Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case.
Lift the camera cable bracket out of the upper case.
Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
Lift the optical drive from its right edge and pull it out of the computer.
Remove the optical drive cable by pulling it straight away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
103 andere personen hebben deze handleiding voltooid.
2 opmerkingen
iFixit rocks! Got a stuck CD out of my wife's superdrive this way. Many thanks!!!
I just took mine apart and found a piece of tape in it. Smh. Works perfect now.
