Inleiding
This guide is an internal private guide used as a prereg.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Using the flat end of a spudger, gently pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
Één andere persoon heeft deze handleiding voltooid.
