Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Verwijder de volgende tien schroeven:
Drie 14.4 mm lange Phillips #00 schroeven
Drie 3.5 mm lange Phillips #00 schroeven
Vier 3.5 mm lange geschouderde Phillips #00 schroeven
Gebruik de voor- of achterkant van een spudger om de batterijaansluiting uit het contact op het moederbord omhoog te wrikken.
Deze stap is niet vertaald. Help het te vertalen
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Remove the following three screws securing the fan to the logic board:
One 7.2 mm T6 Torx screw
Two 5.3 mm T6 Torx screws
Lift the fan out of its recess in the logic board, minding its cable that may get caught.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Disconnect the following four cables:
AirPort/Bluetooth cable
Optical drive cable
Hard drive cable
Trackpad cable
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
If present, remove the small strip of black tape covering the keyboard backlight cable socket.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Remove the following nine screws:
Five 3.6 mm T6 Torx screws
Two 4.3 mm T6 Torx screws
Two 7.2 mm T6 Torx screws
Five 3.0 mm T6 screws
Two 3.6 mm T6 screws
Two 6.7 mm T6 screws
Remove the following two screws:
One 8.6 mm Phillips screw
One 5.5 mm Phillips screw
Remove the display data cable retainer from the upper case.
Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
Remove the logic board.
Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
Remove the MagSafe DC-In board.
55 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Everything ok, only now my screen won`t turn off when I close the lid... Any theories?
just speculation here most laptops have a small magnet and the magnetic reed switch the trip the action to turn off the screen when the lid closes this activating sleep mode
my suspicions are that you damaged the reed switch or you lost a little magnet
Thank you to Phillip for this guide. Completed with no issues. My DC port was wrecked after many years of use and was causing my MBP to only charge intermittently.
Brilliant guide. Thanks. Completed the repair and now it charges perfectly.
