Inleiding
Use this guide to completely replace the logic board.
Gereedschap
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
De-route the microphone cable from its slot molded into the left speaker enclosure.
90 andere personen hebben deze handleiding voltooid.
6 Opmerkingen
Hello guys,
I have a question for you : if i need to change my macbook pro early 2011 logic board (the one with the core i5 2.3ghz) with a late 2011 logic board (core i5 2.8Ghz). will it work ? thanks a ton for any input on that matter !
Should be fine Guillaume, things to note are: The serial number will give the old info of the old main board. Also the CPU cooler my be different, on 1 I noticed the cooler has 2 fans on the 2.3Mhz it has 1. Assuming you have both cases in front of you, I don't see to much of an issue.
I would advise taking the memory out sooner then the last step, as while your trying to maneuver everything around it seems the sticks could get in one's way or even worse break off the retaining tabs for the memory.
i lol @ the spudger !
Hi !!!
I have a MacBook Pro 2011, I ran out of charge on an update (I thought the multi-plug was connected) after what happened I stayed in the limbo. I take it to a technician and manages to put it to work but what happens is that it works very slow "almost impossible". I was told that I should change the hard drive and the memory (you have a SSD 250 hard drive and 8GB C / U memories.) But it continues with the problem of slowness and it works only when the battery is completely lost and recharged And when I turn it off again it returns to slowness.
