Ga door naar hoofdinhoud
MacBook Pro 13" Unibody Early 2011 Upper Case Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 2, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 2, afbeelding 2 van 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Battery Connection: stap 3, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Battery Connection: stap 3, afbeelding 2 van 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 4, afbeelding 1 van 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Fan: stap 5, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Fan: stap 5, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Fan: stap 5, afbeelding 3 van 3
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 6, afbeelding 1 van 1
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 7, afbeelding 1 van 1
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
  8. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Logic Board: stap 8, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Logic Board: stap 8, afbeelding 2 van 2
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
  9. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the camera cable from the logic board.
    • The camera cable slides out from its logic board connector. If your cable feels fragile, use a spudger to walk the cable out from the metal tabs on each side of the connector head.
  10. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 10, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
  11. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 11, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 11, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 11, afbeelding 3 van 3
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
  12. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 12, afbeelding 1 van 1
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
  13. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 13, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 13, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 13, afbeelding 3 van 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  14. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 14, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
  15. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 15, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 15, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 15, afbeelding 3 van 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  16. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 16, afbeelding 1 van 1
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
  17. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 17, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 17, afbeelding 2 van 2
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
  18. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 18, afbeelding 1 van 1
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
  19. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 19, afbeelding 1 van 1
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
  20. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement, Upper Case: stap 20, afbeelding 1 van 1
    • One 5.6 mm Tri-point screw
    • One 13 mm Tri-point screw
  21. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 21, afbeelding 1 van 1
    • Carefully peel the battery warning label off the upper case between the battery and the optical drive.
    • Do not remove the label from the battery.
  22. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 22, afbeelding 1 van 1
    • Use the attached plastic pull tab to help remove the battery from the upper case.
  23. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 23, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 23, afbeelding 2 van 2
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain captive to the hard drive bracket.
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  24. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 24, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 24, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 24, afbeelding 3 van 3
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
  25. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 25, afbeelding 1 van 1
    • Remove the following four screws:
    • Two 3 mm Phillips screws
    • Two 9.7 mm Phillips screws
  26. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 26, afbeelding 1 van 1
    • Carefully peel up the thin IR sensor/sleep LED ribbon cable from the adhesive securing it to the upper case.
  27. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 27, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 27, afbeelding 2 van 2
    • Pull the front hard drive bracket containing the IR sensor/sleep LED away from the front edge of the upper case.
    • Remove the hard drive cable.
  28. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 28, afbeelding 1 van 1
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  29. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 29, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 29, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 29, afbeelding 3 van 3
    • Disconnect the four antenna connectors boxed in red in the first picture.
    • To do so, use the tip of a spudger to pry their connectors up from the sockets on the AirPort/Bluetooth board.
    • De-route each of the cables from their channels in the AirPort/Bluetooth bracket.
  30. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 30, afbeelding 1 van 1
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  31. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 31, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 31, afbeelding 2 van 2
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
    • Remove the AirPort/Bluetooth board assembly.
  32. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 32, afbeelding 1 van 1
    • Remove the three 2.7 mm Phillips screws securing the optical drive to the upper case.
  33. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 33, afbeelding 1 van 1
    • Lift the optical drive from the edge nearest the display and remove it from the upper case.
  34. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 34, afbeelding 1 van 1
    • Peel the right speaker cable off the upper case.
  35. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 35, afbeelding 1 van 2 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 35, afbeelding 2 van 2
    • Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
    • Start prying up from the edge of the right speaker nearest the display. Starting from the other side may damage one of the antennas.
    • Pry up along the edge of the right speaker until it is separated from the upper case.
  36. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 36, afbeelding 1 van 1
    • Pull the right speaker out from under the optical drive opening.
  37. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 37, afbeelding 1 van 1
    • Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
  38. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 38, afbeelding 1 van 1
    • Remove the small piece of foam tape covering the left display hinge screws.
  39. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 39, afbeelding 1 van 1
    • Remove two of the three 6 mm T8 Torx screws securing the left side of the display to the upper case.
  40. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 40, afbeelding 1 van 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
  41. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 41, afbeelding 1 van 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  42. MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 42, afbeelding 1 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 42, afbeelding 2 van 3 MacBook Pro 13" Unibody Early 2011 Upper Case Replacement: stap 42, afbeelding 3 van 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
    • Upper case remains.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 5,929
