Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Remove the lower case to access the internal components of your MacBook Pro.
  1. Remove the following ten screws:
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
    Does void the warranty?
    jfondeur - Antwoord
    No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
    oakdragon12 - Antwoord
    How much weight can I save by removing the optical drive?
    gunes314 - Antwoord
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
    Carlos Duarte do Nascimento - Antwoord
    Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
    Seji the veggie -
    What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
    Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
    pmhparis -
    The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
    While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
    Dan -
    I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
    John Adam Wickliffe - Antwoord
    Hey guys,
    this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
    I posted some pictures on your facebook page..
    renatumb - Antwoord
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - Antwoord
    Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
    kschmesk - Antwoord
    Totally agree!! I used the #00 screwhead for 7 out of the 10, but for the remaining tricky ones I used the #0 screwhead and it helped me out. I was so worried I would strip the tiny screw, but this comment saved me!
    Juliana Mak -
    I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
    Alex - Antwoord
    The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
    . Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
    I got round it by using the camera cable from the old set and cutting off the new one
    brian whittle - Antwoord
    Hello MacWorld,
    Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
    wer 10/5/15
    tayseer999 - Antwoord
    I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
    ForumHermit - Antwoord
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - Antwoord
    on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
    Maximilian Klotz - Antwoord
    I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
    gilded yak - Antwoord
    Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
    Jack - Antwoord
    I have the same question. What is the difference between shouldered and not? So hard to see any difference…
    Michael Wilkens -
    I’ll second that. I could never find them being different.
    otetz -
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - Antwoord
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
    Stephen Smith - Antwoord
    A screw does not come out, how can I get it out? Many thanks in advance for your help
    Wilder Torres - Antwoord
    Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
    airshack - Antwoord
    when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
    this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
    Matt - Antwoord
    It seems to me the yellow and orange screws are the same
    Luca Giancarli - Antwoord
    If you look closely, the four front screws (with the yellow circles) have a short unthreaded section under the head. The orange keyed screws are threaded all the way up.
    Raymond Ives -
    The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
    Don Cely - Antwoord
    Two screw types:
    ______________________________
    Shouldered Unshouldered
    xxxxxxx……….xxxxxxx
    ..xxxxx……..….…….x…….
    …..x……..…...……….x…….
    …..x…………....……..x…….
    El Crashitan - Antwoord
    If you are following this guide to upgrade to a better drive and want to keep your system and data intact I highly recommend first following the guide to Clone an Existing Drive using the recommended free SuperDuper!. That process was a breeze and gives you confidence that the new drive will come up looking exactly the way it did when you started.
    Patrick Langvardt - Antwoord
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - Antwoord
    I did this last weekend, and definitely, a Phillips #000 screwdriver is required (not a Phillips #00!)
    Javier Campos Delgado - Antwoord
    WIll this card be good with MacBookPro 17 inch 2011
    Zafar Ali - Antwoord
    I just followed this guide and it really helped me install a replacement cable and a new Samsung 860 EVO 500gb SSD in my aging MacBook Pro 13 A1278 MID 2012. It’s performing like a new machine now! The guide worked fine, but I’m curious why this HD cable costs €45 on Ifixit’s webshop, and only €13 on Amazon.de (I live in Europe)? The Amazon purchase also included two screwdrivers and a spudger.
    Jeff Baker - Antwoord
  2. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Use your fingers to pry the lower case away from the body of the MacBook near the vent. Remove the lower case.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
    If the black vent window that is attached to the back cover becomes loose what kind of glue should be used to attach it again, thermal paste or super glue?
    Thanks for your help.
    Mikell - Antwoord
    bonjour cette truc ça marche au mac Brook pro Retina ou pas?
    Shi Feng - Antwoord
    Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
    Claire Rapp -
    Merhaba, trackpad değişimi ve ayarlaması için tornavidaya ihtiyacım var, bu konuda yardımcı olabilir misiniz acaba? Ne tür bir tornavidaya ihtiyacım var ve nereden bulabilirim acaba?
    Volkan Ogul - Antwoord
Conclusie
52 andere personen hebben deze handleiding voltooid.
Één commentaar
Has anyone had problems with the screen flickering after assembling the computer again? How can I solve this problem?
Laura Christiansen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 128
Altijd: 31,231
