Inleiding
Use this guide to replace a blown-out left speaker.
Wat je nodig hebt
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
De-route the microphone cable from its slot molded into the left speaker enclosure.
23 andere personen hebben deze handleiding voltooid.
4 opmerkingen
General - the reason you are reading this guide may well be that you blew you speakers after installing 'Boom' from the App Store.
All I can say is, don't install it a second time!
Others, be warned! If you use Boom, just use it at the lowest volume you can. Looks like they don't replace speakers.
Or better, don't install it at all.
Stuart.
You're right, Boom only enjoyable when using headphone, but it also kill internal speaker especially the mini internal subwoofer
You are right, but in my case it was VLC, I pushed the volume up to 200% and same result happened as you said of Boom, a speaker is blown.. LoL. So, same thing goes here, don't use VLC higher volume than 100%.
ottima guida
con un pò di pazienza si ottiene un ottimo risultato
grazie
