Ga door naar hoofdinhoud
Inleiding
Internal Prerequisite.
Onderdelen
Geen onderdelen opgegeven.
  1. Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  2. Carefully pull the camera cable out of its socket on the logic board.
    • Carefully pull the camera cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
  3. Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket. De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  4. Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board. De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
    • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
    • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  5. Using the method described in the last step, disconnect the remaining three antenna connectors. De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
    • Using the method described in the last step, disconnect the remaining three antenna connectors.
    • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
  6. Remove the following five screws:
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  7. Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  8. Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
    • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,051
