Inleiding
Vooraf vereiste handleiding.
Wat je nodig hebt
Gebruik het platte einde van een spudger om de lintkabelaansluiting van de AirPort/Bluetooth-module uit het contact op het logic board omhoog te duwen.
Trek de kabel van de camera voorzichtig uit het contact op het logic voard.
My cable is broken, have the part number or code to buy?
I found there was plenty of length in the camera cable (as it goes around two sides of the optical drive) so does not need to be disconnected - just ease it out of the slot alongside the drive and lay it diagonally across.
Duw de lintkabel van de AirPort/Bluetooth-module uit de weg en peuter de camerakabel los van het kleefmiddel dat het aan de subwoofer en de beugel van de AirPort/Bluetooth-module bevestigt.
Begeleid de camerakabel weg onder de vinger die de kabel vasthoudt en die in de beugel van de AirPort/Bluetooth-module is verwerkt.
Koppel de resterende drie antennekabelaansluitingen met behulp van de methode die in de vorige stap is uitgelegd.
Begeleid de kabels weg uit de inkepingen die in de beugel van de AirPort/Bluetooth-module gesneden zijn.
I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
Actually, on my repair attempt, one antenna cable broke (on the image the bottom right one in the red square), I’m not sure whether it broke already before or was morbid somehow. Fact is. suddenly I had this cable in my fingers, and was sure I completely broke the macbook and need to find a new display now.
But as it turned out: the Mac is still fully working, including WIFI, BT, Camera etc. So apart from my huge relief, I want to address that these cables may break easily at their connection with the display. And that one antenna might be not mandatory for WIFI to work.
How do I know which of these cables goes in which slot when attaching the new display?
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
Greg - Antwoord
