Inleiding
Prerequisite only—remove the logic board and heat sink together as a single assembly, either for further disassembly or simply to get it out of the way.
Wat je nodig hebt
Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket.
Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Using a T3 Torx driver:
Remove two 1.4 mm screws from the Thunderbolt port connector bracket on the left.
Remove two more 1.4 mm screws from the Thunderbolt port connector bracket on the right.
Use a spudger to disconnect the left-side Thunderbolt port connector by prying it straight up from the logic board.
Gently push the connector aside so it won't interfere with logic board removal.
Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside.
Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors.
Use a spudger to disconnect the 3.5 mm audio jack flex cable by prying it straight up from the logic board.
Gently push the flex cable aside.
Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board.
Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable.
Carefully slide an opening pick under the flex cable to separate it from the logic board, and push it carefully aside.
If you have trouble, don't force it—apply a little more heat and try again.
Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket.
Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board.
Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket.
Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board.
Peel back any tape covering the microphone connector socket.
Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board.
Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board.
Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board.
Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board.
Disconnect the first antenna cable by prying it straight up from its socket.
Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle.
Remove all ten screws securing the logic board assembly:
Three 2.5 mm Torx T3 screws
Five 2.9 mm Torx T5 screws
Two 3.0 mm Torx T5 screws
Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
Lift from the left side to remove the logic board assembly.
Check the alignment of the rubber vibration dampers, and adjust them as needed.
Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
