Inleiding
Gebruik deze handleiding om de linkerspeaker te vervangen.
Verwijder de volgende tien schroeven die de onderste behuizing aan de bovenste behuizing bevestigen:
Twee 2.3 mm lange P5 Pentalobe-schroeven
Acht 3.0 mm lange P5 Pentalobe-schroeven
Verwijder de plastic bescherming die aan het contactbord van de batterij is bevestigd.
This plastic cover wasn’t included with the new battery so I placed the original one back in. Was it supposed to go back in? This detail wasn’t clear since the original cover didn’t fit exactly over the newer battery connector. Plus any stickiness of adhesive that may have been there was gone.
Hi, any issues with you computer after a year? I didn’t put mine back in either…
Kevin, I forgot to place mine back in! How is your laptop doing without it?
Is it ok if I did put the plastic cover back in?
yes, it is okay
Verwijder de volgende schroeven die het connectorbord van de batterij aan het logic board bevestigen:
Twee 2.8 mm lange T6 Torx-schroeven
Eén 7.0 mm lange T6 Torx geschouderde schroef
Top screw in this image was not a T6. I found that a T5 bit fit this one.
I can not put back top screw holding the plastic part. Help please
The colors of the circles marking the locations of the screws in the photo are reversed.
stop abusing
Verwijder de breedkop 6.4 mm lange T6 Torx-schroef die de batterijaansluiting aan de logic boardmodule bevestigt.
I lost this screw! How important is it? Will it be okay with just the 3 previously removed screws?
Pak de Interposer met een pincet vast.
Til de Interposer van het logic board af en verwijder deze.
WHy to remove battery contact board? Replace can happen without it also, right.
You don’t want to work on a live system as you could damage parts
Dan -
you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
What happens if the Battery Contact Board fails?
Be extra careful when tightening down on the interposer. When I powered on upon completion, the battery was not connected. When I opened it back up, I saw that one of the little metal nubs holding the interposer in place had snapped off (the one on the side, not the corner). I was able to carefully tighten the wide head screw back in, watching the alignment, and the battery was successfully recognized. Hopefully the connection holds up.
So something similar happened to me. One the the metal alignment nubs snapped off, and when I went to screw down the interposer it started emitting a burning smell. Do you guys think I fried the board? There doesn’t look to be any visual damage but the computer wont turn on.
Geremy C -
Where can I buy a replacement interposer? I may have lost mine in the process of replacing the battery.
земля пухом братан, ты приехал
I really dont understand why to unplug so many parts if the SSD can be easily removed without all this effort. its not even connected to the battery..
I was reassembling and put the interposer back and when the battery contact board touched the interposer, there was a little spark. Should I be worried?
I skipped this step but still OK.
Warning to all: I snapped off the alignment nub as well, as I removed the interposer, and now it won’t start with a brand new battery. Any solutions to a “snapped nub” issue?
Gebruik het platte einde van een spudger om de kabelaansluiting van de hoofdtelefoonjack in een rechte beweging uit het contact op het logic board omhoog te duwen.
Gebruik een T5 Torx-schroevendraaier om de volgende schroeven, die de rechterspeaker aan de bovenste behuizing bevestigen, te verwijderen:
Eén zwarte 6.8 mm lange schroef
Eén zilveren 6.3 mm lange schroef
Eén zwarte 4.9 mm lange schroef
The 6.3mm screw appears to be on the lower central part of the Macbook that I'm working on.
Be very careful on this step. If you aren’t you can snap the plastic on the corners where the screws go in. Remember to go slowly when spinning the screws back in, it doesn’t take gorilla torque to tighten them, just take it easy!
Spencer is right, I think you should update the step 19
Thanks everyone for the heads up! We’ve gone back and remeasured the screws to confirm, and have updated the guide appropriately.
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
18 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
4 Opmerkingen
Rats:
"Wedge the tip of a spudger beneath the left speaker cable connector.
Gently pry the left speaker cable connector up off from its socket on the logic board.
Be sure you are prying up on the connector, not the socket itself."
I accidentally pried up on the socket, which looks like it was soldered to the board. Left speaker doesn't work, of course. I assume there is no fix for this, other than replacing the board??
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm. Changed both speakers as per your other guide.
This was great! I fixed the computer easily.
If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
Toby Thurston - Antwoord
Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
timofej.se -
The colors of the circles marking the locations of the screws are reversed.
Homer Hegedus - Antwoord
On my model A1425 these were all 1.2mm P5 screws. They all looked the same to me.
bigfish333 - Antwoord
This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
Susan Greer - Antwoord
