Inleiding
Use this guide to replace the right speaker.
This guide is for the speaker on the right side of your notebook when operating normally, during most of the guide it will be on the left, as your laptop will be upside down.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$16.96
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
46 andere personen hebben deze handleiding voltooid.
