Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Verwijder de volgende tien schroeven die de onderste behuizing aan de bovenste behuizing bevestigen:
Twee 2.3 mm lange P5 Pentalobe schroeven
Acht 3.0 mm lange P5 Pentalobe schroeven
Deze stap is niet vertaald. Help het te vertalen
Carefully remove the rubber fan bumper from the edge of the heat sink.
Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Remove the following screws securing the heat sink to the logic board:
Four 2.6 mm T5 screws
One 2.4 mm Phillips #000 screw
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Peel the iSight camera cable off the fan housing to fold it out of the way.
Use the tip of a spudger to flip the tab on the fan's ZIF connector.
Carefully pull the fan cable straight out of its socket.
Remove the following screws securing the fan to the upper case:
One 5.0 mm T5 Torx screw
Two 3.6 mm T5 Torx screws
Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket.
Remove the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the I/O board.
Push the I/O board cable up to bend it out of the way.
Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board.
Remove the following screws securing the I/O board to the upper case:
One 3.5 mm T8 Torx standoff screw
One 3.5 mm T5 Torx screw
Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case.
Remove the I/O board.
Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board.
15 andere personen hebben deze handleiding voltooid.
4 opmerkingen
very good instructions—easily followed —-thank you so much for this !!!!!
Thank you very much Sam Goldheart! Following your impeccable instruction and armed with Ifixit instruments, I managed to replace the logic board of my MacBook pro without an issue.
Greetings folks, (I have heard of something stupid, but would give it a try.)
Question where is the HDMI Chip on this board located? I have heard from Heise comments that, when you desolder this chip, theoretically, your MacBook Pro retina 2014 mid 13”/Late2013 13” which was bricked due to the Big Sur Upgrade will functioning again.
I would test it in a few months, if there is no other solution besides a replacement board.
Hi, thank you very much for the guides, great helps! So, I’ve just finished swapping what I thought was a faulty IO board and cable out, and it seems like that may have not been the problem as still none of my outputs work on the right side; HDMI, USB, or SD. What do you think could be the potential cause of the problem, if it wasn’t the IO board as I had originally thought? TIA
