Introduction
Prereq to remove the logic board
Parts
No parts specified.
  1. Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board. Remove the I/O board cable bracket.
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  2. Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board. Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  3. Lift the logic board end of the I/O board cable straight up to bend it out of the way. To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  4. Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board. Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  5. With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board. With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  6. Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board. Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board. Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  7. Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board. Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board. Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  8. Carefully pull the DC-In board connector straight out of its socket on the logic board. Carefully pull the DC-In board connector straight out of its socket on the logic board.
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  9. Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way. Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way. Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  10. If necessary, peel back any tape covering the microphone cable ZIF connector. If necessary, peel back any tape covering the microphone cable ZIF connector.
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  11. Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector. Pull the microphone cable out of its socket on the logic board. Pull the microphone cable out of its socket on the logic board.
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  12. If necessary, peel back any tape covering the keyboard cable connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector.
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  13. Pull the keyboard cable straight out of its ZIF socket on the logic board. Pull the keyboard cable straight out of its ZIF socket on the logic board.
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  14. If necessary, peel back any tape covering the trackpad cable connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector.
    • If necessary, peel back any tape covering the trackpad cable connector.
  15. Pull the trackpad ribbon cable straight out of its socket on the logic board. Pull the trackpad ribbon cable straight out of its socket on the logic board.
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  16. Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  17. Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case. Remove the logic board. When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
Sam Goldheart
448.551 Reputation
547 Guides authored
iFixit Member of iFixit
Community
146 Members
17.274 Guides authored
One Comment
Thanks for the the instructions. I have a question that I couldn’t find on the answers forums. Is there any thermal paste or just general cooling system considerations when replacing the logic board?
Brad Bowman - Antwoord
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 208
