Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Replace the I/O board, which includes the SD card slot, the HDMI port and the right USB port.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
20 andere personen hebben deze handleiding voltooid.
Één opmerking
Thank you! My Macbook was not starting anymore and I saw that it will boot without the IO board. I got a new part, exchanged it and it is now working flawlessly.
